marklythgoe1983 8 Posted November 4, 2020 Share Posted November 4, 2020 (edited) Took the car out for a little drive today normally I only do 8mile to work an back so don't really pay much attention to the boost gauge but watched it for 1st time an its running at 15psi peaks at 20psi then holds at 15psi, does anyone know what power it could be running at its a wrx300 standard is 265bhp am I right in thinking its around 280 maybe a little lower Edited November 4, 2020 by marklythgoe1983 1 Quote Link to post
Full Member ScoobieFloz 15,687 Posted November 10, 2020 Full Member Share Posted November 10, 2020 There are far to many variables to be certain but I would have said it’s close to 260bhp. I have always found boost gauges to read a little higher and not always accurate. However if you add your SIDC sticker you will instantly get another 10 bhp anyway 😂😂😂 Quote Link to post
marklythgoe1983 8 Posted December 30, 2020 Author Share Posted December 30, 2020 ScoobieFloz- sorry for the late reply only just seen your reply its going in for a remap and health check in the new year so just been getting the front mount fitted and changing the up pipe an cats, I've got 2 stickers in the rear windows so does that mean I get 20 extra or is it still just 10 1 Quote Link to post
MarkJHarris 17 Posted December 31, 2020 Share Posted December 31, 2020 15psi is about 1Bar. That's what a 2.5 STI puts out O.E map and should give about 280bhp. Temp dependant. It's about as much as you'd want to put through a WRX gearbox though! Any more you'd need the STI 6 speed. Mine is stabled at 1BAR and gives 285-300bhp depending on temp, runs slightly leaner as it's mapped specifically for V power. On Map2 it gives 1.5BAR, 23psi and that settles at about 360bhp and 400ft/Lb of torque. Frankly I only use that once in a blue moon. Standard is more than enough for normal road use. 1 Quote Link to post
marklythgoe1983 8 Posted January 8 Author Share Posted January 8 MarkJHarris thanks for that mate im on the look out for a 6speed conversion for it as I do a bit of motorway driving Quote Link to post
MarkJHarris 17 Posted January 12 Share Posted January 12 I'd have a long think about that. The 6 speed has the front diff built in- different drive shafts and hubs and uprights ,etc. The rear diff is matched to the gearbox ratios, again you'd need the driveshafts, hubs etc, etc. The 6 speed is a close ratio box and the top ratio isn't really any longer than your fifth. You're buzzing like crazy in an STI on motorways. If you wanted to swap to a 6 speed, with all the extra stuff you'd need, even if you avoided a later DCCD box, you'd be economically better just buying an STI. I didn't just say that because mine's still for sale by the way. 1 Quote Link to post
Join the conversation
