Lockheed
electric wing mirror wont fold
I suspect some one has hit my mirror .
Ive taken it apart , one of the screws was a bit difficult but came off .
How do I get at the motor ? and is it replaceable ? 2004 fsti
Share this post
Link to post
Confirm revision letter C or D - I think we said C on Saturday.
Heated or not mirrors?
RH or LH  side??
Share this post
Link to post
I took my JDM mirrors apart to convert to Heated.
To replace the motor it is the complete item, top left below and as shown on the parts diagram above.
Also the method of attaching the mirror glass varies.
Mine above if you tilt the glass fully so looking upwards, there are two slots on the white backing plate above that you can use a screwdriver in to release the bottom of the glass and then tilt it all the way down and unhook the two pegs at the top.
Noy sure on the earlier models, you used to have to heat the plastic rim of the glass to release it, usually breaking it in the process.
Share this post
Link to post
Do we know if this section with the three bolt holes slide out or does the back of the mirror come off to get at the folding motor ?
Share this post
Link to post
Yuo can remove/replace the blue skull cap but you also need to remove the glass to take out the motor assembly
UK and JDM foresters have totally different part numbers
UK mirrors have non replaceable motors
Share this post
Link to post
The associated mirror HEATED glass appear to have the same part numbers  as UK Newage Imprezas.
Heated Glass  RH - 91039AC180  LH  91039AC190
Rest of mirror including skullcaps are listed as different due to different door mount etc..
Share this post
Link to post
or  £ 270 new just hope a second hand one is on Ebay to make a good one out of two.
Tony
  • Like 1
Share this post
Link to post
Tony
I've just done precisely what you have just suggested :bf:
  • Upvote 1
Share this post
Link to post
Not sure if this the recognised method Subaru use but it should be:cool2: One last problem, I cant see any way of getting the plug through this hole in the trim ?
Share this post
Link to post
You have to de-pin the plug
notice plug removed in my photo
From Litchfield's fitting instructions (carefully making a note of where each wire goes)
Share this post
Link to post
RH motor assembly with heat 91029SA021
LH motor assembly with heat  91029SA031
I think the only difference between non heated motors is the additional wiring required
Looks as if they were fitted to the early  Cross sport as well.
Share this post
Link to post
2 hours ago, Lockheed said:
Thanks again Don , the plug I have is black not white can this be de-dinned ?
Should be able to, but may need a special tool.
if it cant depin. just cut each wire slighly different lengths. solder back together with small shrink tube each cable :boom:
Share this post
Link to post
Most plugs can be de-pinned, you just need to find out how it's achieved.
Here is another example taked from the Subaru Harness repair kit information
Share this post
Link to post
I bought a jdm folding mirror from ebay .. due to turn up tomorrow , the plug and wiring looks identical but we will see .
The colour coded cover certainly is not the same but happily I don't need that bit .
I thank you again ,  some of this stuff just isn't possible with out good help.
  • Upvote 1
Share this post
Link to post
21 hours ago, TheDong said:
Just push it in by hand its much easier........
My hand was just too big and wouldn't fit , how ever this little job went very well after some good advice.
Share this post
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
