Sign in to follow this
ccrien
Advice please ? Rusted front control arms
Hi, just looking at my options since a front control arm on the little impreza ( 2005 GX 4 door ) noticed yesterday has started to rust right through, 7 years since the recall/ inspection.
I doubt subaru would contribute anythng to the repair, and nearest dealership is now quite a few  miles away, so looking at my local independent garage to fit new arms.
Option 1. Source from dealer, tracked them down via web to part no,s 20202FE831 ( replaced 20202FE540 /830) and 20202FE551 (replaced 20202FE550) IF / WHEN available.  Price tbd but expect 250-300 per arm.
option 2.  Tried to source from a few EU based parts websites, there are a load of different impreza steel arms available, prices from £60-120 but none with the link to the original Subaru part no,s I need. Most of those available have different brackets, for the earlier and wrx wagon bushed plastic droplnks, not the balljoint type droplinks on my car.
option 3.  Does anyone know f the WRX saloon alloy arms such as these from ICP, will fit a GX saloon?    Not just for geometry, but the fitting points as well?   Would seem to be the best solution if guaranteed to fit. https://www.importcarparts.co.uk/parts-info?id=2240&cat=96&sub=183&sec=277&var=38&dc=0&gen=&searchKey=&searchPart=
Apparently, the u cradle has to come off or at least  be lowered to get in to change the lower arms, is that right?
Any other ideas welcomed.
Car is far to good to scrap.
cheers
Share this post
Link to post
Thanks very much for that Don, much appreciated.
Didnt realise Rock Auto shipped to the UK
 Will speak to my local garage tomorrow to check theyd be happy fitting these if I sourced them, then will look to get them ordered (and they did the arms on  a wagon WRX a few months back so they should know how to do mine!) .   Some garages are getting reluctant to fit parts they havent sourced themselves.
Share this post
Link to post
11 minutes ago, Lockheed said:
Shudder … import taxes
And its urgent, I cant wait until theres ( maybe?) a free trade deal with the US, So its either Subaru UK/ dealer mark up, or import taxes and VAT on the lot.  Don's indicated total inclusive price looks the better, and unusually, theyre probably better quality than the originals.
Share this post
Link to post
I knew someone would bite . I don't see why the ali ones wont fit ?
What Trump will do is give us a really good deal and then shaft us later on down the line when we are vulnerable ……… the 51st state is coming.
Share this post
Link to post
Ive emailed ICP to see what they say about the wrx alloy arms on a GX, but guessing theres some slight difference in something that means they wont fit.      Cant find anyone thats done it already though, so not hopeful.
Share this post
Link to post
Ive just messaged my only Subaru spanner guy to see if hes done one . Hopefully he will message back tonight if not tomorrow .
Share this post
Link to post
Thanks very much Lockheed,.  The GX is a GD9  so theres possibillity GD9 wrx arms will fit. I will check the handbook tomorrow to see if theres detailed info on front track etc between the two.
Share this post
Link to post
I think this says it all
Share this post
Link to post
just so you know :thumbs:
On £258.08 parts plus Fedex freight of £54.31
£64.04 VAT and £7.01 Import duty
..................and they only have 2 RH ones left in stock
Purchasing Subaru items from Europe they are about €278,98 (inc VAT) EACH
Share this post
Link to post
Cheers Don .
I know its not that much of a deal .
I cant see why the aluminium ones wont work (second hand)
This might be more speedy for the Op
Share this post
Link to post
This one suggests the steel GX arm isnt suitable for the WRX -  -.  "Without wrx," in the description
But doesnt necessarily  mean the alloy WRX arm isnt suitable for the GX?
p.s.  The pic shows the bracket for the plastic bushed bolted droplink, not the balljoint type, so doubtful.
looking like  either ICP alloy arms or more probably the correct part no. Reference from Don's RockAuto steel arms from US, decision and place order tomorrow before the US wake up.
New Steel arms would outlive the rest of the car.
Edited by ccrien
Share this post
Link to post
Especially if treated internally (if possible)
Share this post
Link to post
him mate, was this inspected by subaru and arms passed? or are these replacement arms that have rusted?
Personally after having an arm on my wrx wagon 03 snap on me at thank god low speed id be speaking to Subaru UK. There is still an active recall on these arms so Subaru if passed ok where wrong....any mot inspection will fail them as dangerous to drive.
Id be speaking to Subaru mate asap and i wouldnt drive it...sharp jolt in a pot hole and it will snap.
Share this post
Link to post
Passed the recall inspection back in 2012, a long time ago!      They were also looking fine just a few months ago when i had a good look underneath, but have rotted from the inside since. Only spotted when I had the wheel off the other day, and part of the arm looked dodgy, soon opened up when tapped with a toffee hammer and poked with a screwdriver!
Replacement arms on order from Rock Auto as suggested by Don, u cradle bolt set ordered from ICP, and trying to get through to the nearest dealer for last few bolt/ nuts.   Trusted local garage will fit once Ive got all the bits.
take your point about talking to Subaru, but honestly cant be chewed arguing with them or dealers, rather make my own arrangements.   Guess I should inform them though.
(p.s.  Luke from ICP reckons the alloy wrx arms would fit but may need washers on the front bush delending on subframe.)
Edited by ccrien
Share this post
Link to post
ok mate, understand you want to avoid subaru. mine were replace last year as part of recall, they tried to rip me off for new hubs and wheel bearings, messed up the alignment and stabbed a cv gaiter. Guess i was lucky they replaced mine.
Share this post
Link to post
I count myself lucky I caught it befote it broke!     Shouldnt be like this though, your point is a good one, they should have done a proper replacement job at the original recall.
Share this post
Link to post
I spoke to 2 mechanics today and they said the alloy arms do work. One said they have done it in the past with no issues but since you have the rock items ordered ill just leave this here for posterity.
Why Did I get charged £20 odd import tax for my gauge pod from Ortiz?
Share this post
Link to post
What was the cost and how much the shipping??
I see they are about $150 so £123   On that alone you would pay Import VAT  @20%  so £24 for starters
Share this post
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
