Nogutsnoglory413
Classic Subaru clutch replacement
Hi, I have just bought a 1999
subaru  Impreza T180 FWW. Old school classic reliving my youth. It needs a new clutch due to noisy release bearing.It is totally standard, apart from
pro-drove exhaust.  I had a nightmare with a clutch replacement on our family galaxy , and am keen to find a reliable affordable garage to do the repair. Can anybody recommend one? and give me an idea of what I should be paying ? Thanks in advance.
Share this post
Link to post
1 hour ago, Nogutsnoglory413 said:
Good question ! 😂 Coventry
as its release bearing issue, maynot need flywheel!!!! After 2nd clutch normally needs flywheel depending on driver. :whistle: but definately change flywheel bearing. :ay:
if does needs flwheel, get ACT lightened.
Caution on very cheap fleabay parts. i used to get mid range pice and top quality at AS performance
approx. as guide
 £150-350  Exedy range from 230mm 5 speed kit
£100-250 fitting depends on hourly rate, cash job and experience.
£15 gearbox oil
£15 Fwheel brg
so without Fwheel circa£400 - 450  with£620-700
Tony
Edited by t5nyw
Share this post
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
