Hi all maybe a stupid question but here we go im putting my classic back to as near standard as i can so im getting rid of the induction kit the maf thats on it now is knackered so i managed to get a new one but the diameter of the pipe in the maf housing is smaller than the maf that was on it, the new one is a blueprint part with the same part number as a original subaru one so i can only assume the knackerd maf is the wrong one for the car any ideas on diameter sizes?????? Also will a standard airbox of a uk car fit my jdm car as i wanna put it back on and ditch the induction kit old maf is on the left new maf on the right as you can see the new maf is smaller  any info much appreciated
Edited by scoobyjoff
Share this post
Link to post
Quick update the new maf is the wrong size its for a uk car which is 80mm and the part number on the box says its a 90mm gggrrrr guess ill send it back
Share this post
Link to post
Well orange maf arrived fitted it and car starts no problem it idles for about 30secs then just dies any ideas before i get a gallon of V-POWER and a match !!!!! And send it to the great subaru gods in the sky :foo::foo:
Share this post
Link to post
Does it stay running if you keep your foot on the accelerator and keep the car at about 1000 RPM?
Share this post
Link to post
Hi don i did a ecu reset amd the CEL light is no longer on it fires up atraight the way and runs on choke for about 30secs then gives up ive made no adjustment on the idle control valve as this is the other classic i bought since selling the v2 ive only changed the maf on this one
Share this post
Link to post
I was wondering which of them you were messing around with 😄
I assume if you keep it running using the throttle for a few minutes it dies straight away or does it always cut out after 30(ish) seconds?
Share this post
Link to post
If i leave it on idle after first starting it dies after about 30secs but if i keep my foot on the throttle atnabout 1500revs it runs but a bit lumpy and as soon as throttle released it dies
Share this post
Link to post
Take the Oil filter cap off and try (It's magic 😏
Is the replacement MAF faulty? I assume is was not new. Have you still got the other scoob? can you scavenge parts from that to do a test?
Share this post
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
